ucooper
查看ucooper的 主题 / 回贴
楼主  发表于: 2010-10-09 22:49
之前做项目的时候,查阅了大量资料,终于解决了将归档数据写入listviews控件的功能,这里将我的代码发出来以供参考。注意,里面的一些参数需要根据你的具体需要进行修改。
本人还总结了一份技术文档,由于这里不能上传上传文档,请到我的个人博客里下载吧:
http://www.ucooper.com/wincc-summary.html
Sub  OnLButtonDown(ByVal  Item,  ByVal  Flags,  ByVal  x,  ByVal  y)
Dim  sPro,sDsn,sSer,sCon,sSql,oRs,conn,oCom,oItem,m,  n,  s,i,oList
sPro  =  "Provider=WinCCOLEDBProvider.1;"
sDsn  =  "Catalog=CC_tanks_09_07_14_10_38_56R;"
sSer  =  "Data  Source=.\WinCC"
sCon  =  sPro  +  sDsn  +  sSer
sSql  =  "TAG:R,'tanks\aa','2009-07-16  00:00:00','2009-07-17  00:00:00'"
MsgBox  "Open  with:"  &  vbCr  &  sCon  &  vbCr  &  sSql  &  vbCr
Set  conn  =  CreateObject("ADODB.Connection")
conn.ConnectionString  =  sCon
conn.CursorLocation  =  3
conn.Open
Set  oRs  =  CreateObject("ADODB.Recordset")
Set  oCom  =  CreateObject("ADODB.Command")
oCom.CommandType  =  1
Set  oCom.ActiveConnection  =  conn
oCom.CommandText  =  sSql
Set  oRs  =  oCom.Execute
n=oRs.RecordCount
MsgBox(n)
Set  oList  =  ScreenItems("控件1")
        oList.ListItems.Clear
        olist.ColumnHeaders.clear
        oList.View  =3    //显示样式,3为报表样式
        oList.GridLines  =True    //显示网格
        olist.ColumnHeaders.Add,  ,  CStr(oRs.Fields(0).Name),150
        oList.ColumnHeaders.Add,  ,  CStr(oRs.Fields(1).Name),150
        oList.ColumnHeaders.Add,  ,  CStr(oRs.Fields(2).Name),150
        oList.ColumnHeaders.Add,  ,  CStr(oRs.Fields(3).Name),150
        oList.ColumnHeaders.Add,  ,  CStr(oRs.Fields(4).Name),150
        'ListView1.ColumnHeaders.Add,  ,  CStr(oRs.Fields(3).Name),150
        If(n>0)  Then
          oRs.MoveFirst
        End  If
        m  =  0
        Do  While  Not  oRs.EOF
                  m  =  m  +  1
                  Set  oItem  =  oList.ListItems.Add()
                        oItem.text=CStr(oRs.Fields(0).value)
                        '  oItem.SubItems(1)="bb"
                        '  oItem.SubItems(2)="cc"
                        oItem.SubItems(1)  =  CStr(DateAdd("h",  -8,oRs.Fields(1).value))
                        oItem.SubItems(2)  =  CStr(oRs.Fields(2).value)
                        oItem.SubItems(3)  =  CStr(oRs.Fields(3).value)
                        oItem.SubItems(4)  =  CStr(oRs.Fields(4).value)
                        '  oItem.Text  =  Left(CStr(oRs.Fields(1).Value),  23)
                        '  oItem.SubItems(1)  =  FormatNumber(oRs.Fields(2).Value,  4)
                        '  oItem.SubItems(2)  =  Hex(oRs.Fields(4).Value)
                          If  m  >  100  Then
                                Exit  Do
                            Else
                          End  If
                          oRs.MoveNext
          Loop
         MsgBox("wwwww")
oRs.Close
Set  oRs  =  Nothing
conn.Close
Set  conn  =  Nothing
End  Sub
