ucooper
查看ucooper的 主题 / 回贴
楼主  发表于: 2010-10-09 22:47
之前做项目的时候,查阅了大量资料,终于解决了将归档数据导出到excel的功能,这里将我的代码发出来以供参考。注意,里面的一些参数需要根据你的具体需要进行修改。
本人还总结了一份技术文档,由于这里不能上传上传文档,请到我的个人博客里下载吧:
http://www.ucooper.com/wincc-summary.html
Sub  OnLButtonDown(ByVal  Item,  ByVal  Flags,  ByVal  x,  ByVal  y)
Dim  sPro,sDsn,sSer,sCon,sSql,oRs,conn,oCom,oItem,m,n,s,i,hourdate,secdate
Dim  k,oList,objExcelApp,oItem2,dt1,dt2,dstr1,dstr2,dstr3,dstr4
sPro  =  "Provider=WinCCOLEDBProvider.1;"
sDsn  =  "Catalog=CC_tanks_09_07_14_10_38_56R;"        '根据实际情况修改,查SQLSERVER
sSer  =  "Data  Source=.\WinCC"
sCon  =  sPro  +  sDsn  +  sSer
sSql  =  "TAG:R,'tanks\aa','2009-07-16  12:30:00.000','2009-07-16  13:00:00.000'"      'tanks是归档名  aa  是变量名
MsgBox  "Open  with:"  &  vbCr  &  sCon  &  vbCr  &  sSql  &  vbCr
Set  conn  =  CreateObject("ADODB.Connection")
conn.ConnectionString  =  sCon
conn.CursorLocation  =  3
conn.Open
Set  oRs  =  CreateObject("ADODB.Recordset")
Set  oCom  =  CreateObject("ADODB.Command")
oCom.CommandType  =  1
Set  oCom.ActiveConnection  =  conn
oCom.CommandText  =  sSql
Set  oRs  =  oCom.Execute
n=oRs.RecordCount
MsgBox(n)
'oRs.MoveFirst
Set  objexcelApp=CreateObject("excel.application")
objexcelApp.visible=True
objexcelapp.workbooks.open"d:\book.xls"        '首先要创建这个文件
objExcelApp.Sheets(1).Range("a"&Trim(1))  =oRs.Fields(0).Name
objExcelApp.Sheets(1).Range("b"&Trim(1))  =  oRs.Fields(1).Name
objExcelApp.Sheets(1).Range("c"&Trim(1))  =  oRs.Fields(2).Name
objExcelApp.Sheets(1).Range("d"&Trim(1))  =  oRs.Fields(3).Name
objExcelApp.Sheets(1).Range("e"&Trim(1))  =  oRs.Fields(4).Name
For  i=1  To  oRs.RecordCount
'NewDate  =  DateAdd("h",  8,  "FormatNumber(oRs.Fields(1).value,  1)")
objExcelApp.Sheets(1).Range("a"&Trim(i+1))  =oRs.Fields(0).value
objExcelApp.Sheets(1).Range("b"&Trim(i+1))  =DateAdd("h",+8,oRs.Fields(1).value)
objExcelApp.Sheets(1).Range("c"&Trim(i+1))  =oRs.Fields(2).value
objExcelApp.Sheets(1).Range("d"&Trim(i+1))  =oRs.Fields(3).value
objExcelApp.Sheets(1).Range("e"&Trim(i+1))  =oRs.Fields(4).value
oRs.MoveNext
Next
oRs.Close
Set  oRs  =  Nothing
conn.Close
Set  conn  =  Nothing
objexcelapp.activeworkbook.save
objexcelapp.workbooks.close
'Set  objexcelapp.workbooks=Nothing
objexcelapp.quit
MsgBox("aa")
Set  objexcelapp=Nothing
MsgBox("bb")
MsgBox("导出成功!!")
End  Sub
