szltx
查看szltx的 主题 / 回贴
楼主  发表于: 2007-11-20 18:44
供应三菱A系列可编程控制器(VVVF)
价格面议,量大从优。
深圳市菱泰兴科技有限公司
电话:0755-86368150
传真:0755-86369202
联系人:刘生
手机:13267152530
128KWROM     128K 内存用于 AD51H, AD57G     1,600.00
16KHROM     16K 步 EP-ROM 内存用于 AD57(S1/S2), AD58     2,030.00
16KQROM     EP-ROM MEMORY+B213    2,030.00
16KRAM     16K STEP RAM     2,180.00
16KROM    16K STEP EP-ROM     2,030.00
256KWROM     256K 内存用于 AD51H, AD57G     2,010.00
4KEROM     EP-ROM MEMORY    1,350.00
4KRAM     4K STEP MEMORY (A1N, A3NMCA-0)     1,080.00
4KROM     4K STEP EP-ROM (A1N, A3NMCA-0)     810.00
64KWROM    56K BYTE MEMORY FOR AD51H, AD57G    1,210.00
8KROM    8K STEP EP-ROM    1,350.00
A0J2HCPU     8K STEPS, 480 I/O, 1.25uS/STEP     5,100.00
A11VC     VOICE OUTPUT MODULE     14,160.00
A1NCPU     6KSTEPS, 256 I/O     11,330.00
A1NCPUP21     A1NCPU WITH MELSECNET II OPTICAL DATA LINK     22,250.00
A1NCPUR21     A1NCPU WITH MELSECNET II COAXIAL DATA LINK     22,250.00
A1S32B     BASE UNIT: CPU, 2 I/O & POWER SUPPLY SLOTS     1,000.00
A1S33B     BASE UNIT: CPU, 3 I/O & POWER SUPPLY SLOTS     1,080.00
A1S35B     BASE UNIT: CPU, 5 I/O & POWER SUPPLY SLOTS     1,100.00
A1S38B     BASE UNIT: CPU, 8 I/O & POWER SUPPLY SLOTS     1,660.00
A1S38HB     QnAS BASE UNIT, 8 I/O, HIGH SPEED ACCESS TIME     2,510.00
A1S42X    64 PT. DYNAMIC INPUT    3,050.00
A1S52B-S1     EXTENSION UNIT : 2 I/O SLOTS    950.00
A1S55B-S1     EXTENSION UNIT : 5 I/O SLOTS     1,060.00
A1S58B-S1     EXTENSION UNIT : 8 I/O SLOTS     1,560.00
A1S61PN     INPUT : AC 100 - 240VAC OUTPUT : DC 5V 8A     1,560.00
A1S62DA     D/A CONVERTER : 2 CH., 4-20mA, OR -10V-+10V     4,990.00
A1S62PN     INPUT : AC 100 - 220VAC OUTPUT : DC 5V 5A, DC 24V 0.8A     1,790.00
A1S62RD3N    TEMPERATURE SENSOR : PT-100, 3 WIRES     5,940.00
A1S62RD4N    TEMPERATURE SENSOR : PT-100, 4 WIRES     5,940.00
A1S63ADA     A/D, D/A CONVERTER : 2 INPUT/1 OUTPUT, 4-20mA, OR -10V-+10V     4,690.00
A1S63P     INPUT : DC 24V OUTPUT : DC 5V 8A    2,710.00
A1S64AD     A/D CONVERTER : 4 CH., 4-20mA, OR -10V-+10V     4,240.00
A1S64TCRTBW-S1    3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS     10,430.00
A1S64TCRT-S1    THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL     8,020.00
A1S64TCTTBW-S1     3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS     10,430.00
A1S64TCTT-S1    THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL     8,020.00
A1S65B-S1     EXTENSION UNIT : 5 I/O, POWER SUPPLY SLOTS     1,170.00
A1S66ADA     A/D, D/A CONVERTER : 4 INPUT/2 OUTPUT, 4-20mA, OR -10V-+10V     8,160.00
A1S68AD     A/D CONVERTER : 8 CH., 0-20mA, OR -10V-+10V     6,480.00
A1S68B-S1     EXTENSION UNIT : 8 I/O, POWER SUPPLY SLOTS     1,720.00
A1S68DAI    D/A CONVERTER UNIT : 8 CH., 4-20mA     8,430.00
A1S68DAV    D/A CONVERTER UNIT : 8 CH., -10V-+10V     8,430.00
A1S68TD    THERMOCOUPLE INPUT : 8 CH., B, R, S, E, J, K TYPE     12,110.00
A1SC01B     55 mm EXTENSION CABLE     360.00
A1SC03B     300 mm EXTENSION CABLE    420.00
A1SC05NB     450 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT     660.00
A1SC07B     0.7M BUS CONNECTION (AnS/QnAS CPU)     590.00
A1SC07NB     700 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT     780.00
A1SC12B    1.2M BUS CONNECTION (AnS/QnAS CPU )     850.00
A1SC30B     3M BUS CONNECTION (AnS/QnAS CPU)     1,350.00
A1SC30NB     3 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT    1,980.00
A1SC50B    5M BUS CONNECTION (AnS/QnAS CPU)     1,990.00
A1SC50NB     5 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT     2,650.00
A1SC60B    6 M EXTENSION CABLE     2,140.00
A1SCPUC24-R2     CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, RS232 PORT     7,730.00
A1SD51S    RS232C 2 CH., RS422/484 1 CH.     9,190.00
A1SD61     HIGH SPEED COUNTER, 1 CH., 50KPPS     6,210.00
A1SD62     HIGH SPEED COUNTER, 2 CH., 100KPPS, SINK     6,380.00
A1SD62D     HIGH SPEED COUNTER, 2 CH., 200KPPS, SINK     6,830.00
A1SD62E     HIGH SPEED COUNTER, 2 CH., 100KPPS, SOURCE     6,380.00
A1SD70     1 AXES, VOLTAGE OUTPUT     7,820.00
A1SD71-S2     2 AXIS, PULSE TRAIN, OUTPUT, SPEED CONTROL FUNCTION     13,980.00
A1SD71-S6     2 AXIS, PULSE TRAIN OUTPUT     14,530.00
A1SD71-S7     2 AXIS, PULSE TRAIN OUTPUT, MANUAL PULSAR INPUT     13,980.00
A1SD75-C01H     CONNECTION CABLE BETWEEN A1SD75 & AD75TU     880.00
A1SD75M1     SSC NET, 1ASIS     6,830.00
A1SD75M2     SSC NET, 2ASIS     10,430.00
A1SD75M3     SSC NET, 3ASIS     14,450.00
A1SD75P1-S3     1 AXES, PULSE TRAIN OUTPUT     7,270.00
A1SD75P2-S3     2 AXIS, PULSE TRAIN OUTPUT    11,000.00
A1SD75P3-S3     3 AXIS, PULSE TRAIN OUTPUT     15,420.00
A1SG60     BLANK COVER     160.00
A1SG62    DUMMY I/O MODULE, 16/32/64 SELECTABLE     1,140.00
A1SH42     DC 12/24V : 32 PT. SINK INPUT ; 32 PT. SINK TRANSISTOR OUTPUT    4,120.00
A1SHCPU     CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256     4,010.00
A1SI61     16 PT. INTERRUPT MODULE     3,100.00
A1SJ51T64    MELSECNET I/O LINK MASTER, 64 REMOTE I/O CONTROL     1,940.00
A1SJ61BT11    CC-LINK MASTER STATION MODULE    2,790.00
A1SJ61QBT11     CC-LINK MASTER MODULE     2,870.00
A1SJ71AP21     MELSECNET/II, MASTER/LOCAL, FIBER OPTIC SI-200/250     11,710.00
A1SJ71AR21     MELSECNET/II, MASTER/LOCAL, COAXIAL CABLE     11,710.00
A1SJ71AT21B     MELSECNET/B, MASTER/LOCAL     7,770.00
A1SJ71BR11     MELSECNET/10, COAXIAL CABLE     13,910.00
A1SJ71E71N-B2    ETHERNET INTERFACE UNIT, 10BASE2     15,460.00
A1SJ71E71N-B5T     ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5     15,460.00
A1SJ71LP21     MELSECNET/10, OPTICAL FIBER SI-200/250     13,910.00
A1SJ71LP21GE     MELSECNET/10, OPTICAL FIBER GI-62.5/125     22,470.00
A1SJ71LR21     MELSECNET/10, 同轴电缆    13,910.00
A1SJ71PB92D     PROFIBUS-DP INTERFACE MODULE     20,660.00
A1SJ71PB96F     PROFIBUS-FMS INTERFACE MODULE     20,660.00
A1SJ71PT32-S3    MELSECNET/MINI-S3 MASTER, OPTICAL/TWISTED PAIR     5,100.00
A1SJ71QBR11     MELSECNET/10 , COAXIAL, COMPACT TYPE     14,740.00
A1SJ71QC24     RS232C &RS422 I/F, COMPACT TYPE     7,370.00
A1SJ71QC24N     RS232C &RS422 I/F, COMPACT TYPE(NEW)     7,050.00
A1SJ71QC24-R2     RS232 I/F, 2 CH, COMPACT TYPE    7,370.00
A1SJ71QE71N-B2     ETHERNET INTERFACE UNIT, 10BASE2     16,050.00
A1SJ71QE71N-B5T     ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5     16,050.00
A1SJ71QLP21     MELSECNET/10 , SI-200/250 FIBRE OPTIC, COMPACT TYPE     15,110.00
A1SJ71T32-S3    MELSECNET/MINI-S3 MASTER, TWISTED PAIR     4,620.00
A1SJ71UC24-PRF    RS232C INTERFACE & PRINTER FUNCTION     6,160.00
A1SJ71UC24-R2    RS232C INTERFACE    4,800.00
A1SJ71UC24-R2-S2    MODUS, RS232C INTERFACE     5,720.00
A1SJ71UC24-R4    RS422/485 INTERFACE     4,800.00
A1SJ71UC24-R4-S2    MODUS, RS422/485 INTERFACE     3,960.00
A1SJ72QBR15     MELSECNET/10 REMOTE I/O MODULE, COAXIAL    14,740.00
A1SJ72QLP25     MELSECNET/10 REMOTE I/O MODULE, OPTICAL     14,740.00
A1SJ72T25B    MELSECNET/B, REMOTE STATION     13,010.00
A1SJHCPU     CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, 5 I/O SLOTS     3,940.00
A1SJHCPU-S8     CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, 8 I/O SLOTS    4,460.00
A1SNMCA-2KE     MEMORY CASSETTE : 2K STEP EEPROM    1,020.00
A1SNMCA-8KE     MEMORY CASSETTE : 8K STEP EEPROM     2,030.00
A1SNMCA-8KP     MEMORY CASSETTE : 8K STEP EPROM    860.00
A1SP60     PULSE CATCH MODULE     2,330.00
A1ST60    8 ANALOG TIMERS     2,180.00
A1STA32     32 PTS, AWG 20 (0.5mm2), FOR A1SX41/42-S2/71, A1SY41/71     560.00
A1STA32-3     32 PTS, AWG 22 (0.3mm2), FOR A1SX41/42-S2/71, A1SY41/71     560.00
A1STA32-7    32 PTS, AWG 18 (0.7mm2), FOR A1SX41/42-S2/71, A1SY41/71     560.00
A1SX10    16 PT. AC 100V    1,560.00
A1SX10EU     16 PTS. AC 100V, EN/IEC STANDARD     1,750.00
A1SX20    16 PT. AC 200V    2,100.00
A1SX20EU     16 PTS. AC 200V, EN/IEC STANDARD     2,210.00
A1SX30    16 PT. AC 24V OR DC 24V     1,520.00
A1SX40    16 PT. DC 12/24V, SINK INPUT     1,480.00
A1SX40-S1     16 PT. DC 24V, SINK INPUT, FAST RESPONSE     1,560.00
A1SX40-S2    16 PT. DC 24V, SINK INPUT    1,480.00
A1SX41     32 PT. DC 12/24V, SINK INPUT     2,560.00
A1SX41-S1     32 PT. DC 24V, SINK INPUT, FAST RESPONSE    2,870.00
A1SX41-S2     32 PT. DC 24V, SINK INPUT    2,560.00
A1SX42     64 PT. DC 12/24V, SINK INPUT     4,120.00
A1SX42-S1     64 PT. DC 24V, SINK INPUT, FAST RESPONSE     4,620.00
A1SX42-S2    64 PT. DC 24V, SINK INPUT    4,120.00
A1SX48Y18     8 PT. DC 12/24V SINK INPUT ; 8 PT. RELAY OUTPUT     1,960.00
A1SX48Y58     8 PT. DC 12/24V SINK INPUT ; 8 PT. SINK TRANSISTOR OUTPUT     1,320.00
A1SX71     32 PT. DC 5/12V, SINK/SOURCE INPUT    2,790.00
A1SX80    16 PT. DC 12/24V, SINK/SOURCE INPUT     1,880.00
A1SX80-S1     16 PT. DC 24V, SINK/SOURCE IN (HIGH SPEED)     1,880.00
A1SX80-S2     16 PT. DC 24V, SINK/SOURCE INPUT     1,880.00
A1SX81     32 PT. DC 12/24V, SINK/SOURCE INPUT     3,190.00
A1SX81-S2    32 PT. DC 24V, SINK/SOURCE INPUT     3,190.00
A1SY10     16 PT. AC 240V/DC 24V, 2A, RELAY     2,030.00
A1SY10EU     16 PT. AC 240V/DC 24V 2A, RELAY, EN/IEC STANDARD     2,210.00
A1SY14EU     12 PT. AC 240V/DC 24V 2A, RELAY, EN/IEC STANDARD     2,210.00
A1SY18A    8 PT. AC 240V/DC 24V 2A, RELAY, INDEPENDENT COMMON     1,880.00
A1SY18AEU     8 PT. AC 240VDC 24V 2A, RELAY, EN/IEC STANDARD    1,980.00
A1SY22    16 PT. AC 240V 0.6A, TRIAC/SSR    2,490.00
A1SY28A     8 PT. AC 24V 1A, TRIAC/SSR, INDEPENDENT COMMON    2,180.00
A1SY28EU     8 PT. AC 240V 1A, TRIAC/SSR, EN/IEC STANDARD     2,420.00
A1SY40     16 PT. DC 12/24V 0.1A, TRANSISTOR SINK     1,480.00
A1SY41     32 PT. DC 12/24V 0.1A, TRANSISTOR SINK     2,560.00
A1SY42     64 PT. DC 12/24V 0.1A, TRANSISTOR SINK    4,120.00
A1SY50    16 PT. DC 12/24V 0.5A, TRANSISTOR SINK     1,560.00
A1SY60    16 PT. DC 24V 2A, TRANSISTOR SINK     3,100.00
A1SY68A     8 PT. DC 5/12/24/48V 2A, TRANSISTOR SINK/SOURCE     2,180.00
A1SY71     32 PT. DC 5/12V 16mA, TRANSISTOR SINK     2,560.00
A1SY80     16 PT. DC 12/24V 16mA, TRANSISTOR SOURCE     2,030.00
A1SY81     32 PT. DC 12/24V 0.1A, TRANSISTOR SOURCE     3,510.00
A2ACPU     14KSTEPS, 512 I/O, HIGH FUNCTION     13,450.00
A2ACPUP21     A2ACPU WITH MELSECNET II OPTICAL DATA LINK     20,640.00
A2ACPUP21-S1     A2ACPU-S1 WITH MELSECNET II OPTICAL DATA LINK     20,640.00
A2ACPUR21     A2ACPU WITH MELSECNET II COAXIAL DATA LINK     20,640.00
A2ACPUR21-S1     A2ACPU-S1 WITH MELSECNET II COAXIAL DATA LINK     20,640.00
A2ACPU-S1     14KSTEPS, 1024 I/O, HIGH FUNCTION     13,450.00
A2ASCPU     CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 512, 0.2us/STEP     7,820.00
A2ASCPU-S1     CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 1024, 0.2us/STEP    9,390.00
A2ASCPU-S60     CPU, BUILT IN 30KSTEPS RAM, MAX. I/O 1024, 0.15us/STEP     20,140.00
A2NCPU     14KSTEPS, 512 I/O     12,140.00
A2NCPUP21     A2NCPU WITH MELSECNET II OPTICAL DATA LINK     21,850.00
A2NCPUP21-S1     A2NCPU-S1 WITH MELSECNET II OPTICAL DATA LINK     21,850.00
A2NCPUR21     A2NCPU WITH MELSECNET II COAXIAL DATA LINK     21,850.00
A2NCPUR21-S1     A2NCPU-S1 WITH MELSECNET II COAXIAL DATA LINK     21,850.00
A2NCPU-S1    14KSTEPS, 1024 I/O     13,760.00
A2SHCPU     CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 512     5,840.00
A2SHCPU-S1     CPU, BUILT IN 14KSTEPS RAM, MAX. I/O 1024    6,420.00
A2SMCA-14KP    MEMORY CASSETTE : 14K STEP EPROM    1,170.00
A2SMCA-30KP    MEMORY CASSETTE : 30K STEP EPROM    1,540.00
A2SMCA-60KE    MEMORY CASSETTE : 60K STEP EEPROM     3,080.00
A2SNMCA-30KE    MEMORY CASSETTE : 30K STEP EERPOM     2,180.00
A2SWA-28P     READ/WRITE ADAPTER FOR A2SMCA-14KP     620.00
A2USHCPU-S1     CPU, BUILT IN 30KSTEPS RAM, MAX. I/O 1024, 0.09us/STEP     9,390.00
A32B     BASE UNIT WITH : CPU, 2 I/O & POWER SUPPLY SLOTS     1,660.00
A32RB    Q4AR DUAL SYS. BASE, 2 I/O SLOTS    5,600.00
A33RB     Q4AR DUAL SYS. BASE, 3 I/O SLOTS     6,390.00
A35B     BASE UNIT WITH : CPU, 5 I/O & POWER SUPPLY SLOTS     2,230.00
A37RHB     Q4AR/QnA BASE, 7 I/O, , 2 POWER, 1 CPU SLOTS    4,470.00
A38B     BASE UNIT WITH : CPU, 8 I/O & POWER SUPPLY SLOTS     3,730.00
A38HB     QnA BASE UNIT, 8 I/O, HIGH SPEED ACCESS TIME     3,480.00
A3ACPU     (30K+30K)STEPS, 2048 I/O, HIGH FUNCTION (0.15 uS/STEP)     31,660.00
A3ACPUP21     A3ACPU WITH MELSECNET II OPTICAL DATA LINK     38,850.00
A3ACPUR21     A3ACPU WITH MELSECNET II COAXIAL DATA LINK     38,850.00
A3NCPU     (30K+30K)STEPS, 2048 I/O     32,370.00
A3NCPUP21     A3NCPU WITH MELSECNET II OPTICAL DATA LINK     40,470.00
A3NCPUR21     A3NCPU WITH MELSECNET II COAXIAL DATA LINK     40,470.00
A3NMCA-0    MEMORY CASSETTE : NO MEMORY, USE 4K RAM IC     3,080.00
A3NMCA-16     MEMORY CASSETTE : 128K BYTE MEMORY RAM     9,710.00
A3NMCA-2     MEMORY CASSETTE : 16K BYTE MEMORY RAM     3,230.00
A3NMCA-24    MEMORY CASSETTE : 192K BYTE MEMORY RAM     12,140.00
A3NMCA-4     MEMORY CASSETTE : 32K BYTE MEMORY RAM     4,040.00
A3NMCA-40     MEMORY CASSETTE : 320K BYTE MEMORY RAM     16,180.00
A3NMCA-56     MEMORY CASSETTE : 448K BYTE MEMORY RAM     20,230.00
A3NMCA-8     MEMORY CASSETTE : 64K BYTE MEMOR RAM     7,290.00
A42XY     64 PT. INPUT, 64 PT. SINK OUTPUT, DC 12/24V, 55/180mA     6,880.00
A52B     EXTENSION UNIT WITH : 2 I/O SLOTS     1,870.00
A55B     EXTENSION UNIT WITH : 5 I/O SLOTS     2,750.00
A58B     EXTENSION UNIT WITH : 8 I/O SLOTS     2,780.00
A60MX    MULTIPLEXER UNIT : 16 CHANNELS, NON-ISOLATED     13,760.00
A60MXR     MULTIPLEXER UNIT : 16 CHANNELS, ISOLATED MERCURY RELAY     16,180.00
A60MXT     THERMOCOUPLER MULTIPLEXER UNIT : 16 CHNNELS     22,660.00
A616AD     A/D CONVERTER : 16 CH., 4-20mA, OR -10V-+10V     20,230.00
A616DAI     D/A CONVERTER UNIT : 16 CHANNELS, CURRENT OUTPUT    28,780.00
A616DAV     D/A CONVERTER UNIT : 16 CHANNELS, VOLTAGE OUTPUT     28,780.00
A616TD     THERMOCOUPLER CONVERTER UNIT : 16 CHANNELS     20,230.00
A61P     INPUT : AC 110/240V OUTPUT : DC 5V 8A     3,080.00
A61RP     AC100-120/200-240V INPUT, DC 5V 8A OUTPUT     6,940.00
A62B     EXTENSION UNIT WITH : 2 I/O, POWER SUPPLY SLOTS     2,030.00
A62DA     CONVERTER UNIT : 2 CH., 4-20mA OR -10V-+10V     10,070.00
A62DA-S1    D/A CONVERTER UNIT : 2 CH., 4-20mA, 0-20mA OR -10V-+10V     10,070.00
A62P     INPUT : AC 110/240V OUTPUT : DC 5V 5A, DC 24V 0.8A     4,450.00
A63P     INPUT : DC 24V OUTPUT : DC 5V 8A     7,690.00
A65B     EXTENSION UNIT WITH : 5 I/O, POWER SUPPLY SLOTS     3,080.00
A65P     INPUT : AC 110/240V OUTPUT : DC 5V 2A, DC 24V 1.5A     5,260.00
A66P     INPUT : AC 110/240V OUTPUT : DC 24V 1.2A     4,040.00
A68AD     CONVERTER : 8 CH., 4-20mA, OR -10V-+10V     11,330.00
A68ADN     A/D CONVERTER : 8 CH., 0-20mA OR -10V-+10V (HIGH RESOLUTION)     11,330.00
A68B     EXTENSION UNIT WITH : 8 I/O, POWER SUPPLY SLOTS     4,450.00
A68DAI-S1     D/A CONVERTER UNIT : 8 CHANNELS     17,990.00
A68DAV    D/A CONVERTER UNIT : 8 CHANNELS, VOLTAGE OUTPUT     17,990.00
A68P     INPUT : AC 110/240V OUTPUT : DC 1.5V     4,860.00
A68RB     Q4AR/QnA EBASE, 7 I/O, , 2 POWER, 2 CPU SLOTS     5,210.00
A68RD3N     THERMOCOUPLE INPUT UNIT : PT100, 3 WIRES     11,330.00
A68RD4N    THERMOCOUPLE INPUT UNIT : PT100, 4 WIRES     11,330.00
A6BAT     BATTERY FOR MEMORY BACKUP     340.00
A6BR10    MELSECNET/10 COAXIAL CABLE REPEATER    14,400.00
A6BR10-DC     MELSECNET/10 COAXIAL CABLE REPEATER, DC24V P/S     14,400.00
A6BSW-P-S3     BYPASS SWITCH    29,030.00
A6BSW-P-S4     BYPASS SWITCH     29,030.00
A6BSW-P-S5     BYPASS SWITCH     29,030.00
A6CAP-DC1     DUST PROOF CAP     200.00
A6CON1     SOLDERING 32-pt CONNECTOR     180.00
A6CON1E     SOLDERING 32-pt CONNECTOR     180.00
A6CON2     CRIMP-CONTACT CONNECTION 32-pt CONNECTOR     200.00
A6CON2E     CRIMP-CONTACT CONNECTION 32-pt CONNECTOR     210.00
A6CON3     FLAT CABLE PRESSURE-DISPLACEMENT 32-pt CONNECTOR     140.00
A6CON3E     FLAT CABLE PRESSURE-DISPLACEMENT 32-pt CONNECTOR     140.00
A6CON-LJ5P     ONLINE CONNECTOR FOR COMMUNICATION    750.00
A6CON-P214     TRANSPARENT PLUGS FOR ONE TOUCH CONNECTOR,     380.00
A6CON-P220     YELLOW PLUGS FOR ONE TOUCH CONNECTOR,     380.00
A6CON-P514     RED PLUGS FOR ONE TOUCH CONNECTOR,     380.00
A6CON-P520     BLUE PLUGS FOR ONE TOUCH CONNECTOR,     380.00
A6CON-PWJ5P     ONLINE CONNECTOR FOR POWER SUPPLY     750.00
A6CPA-WP1     WATER PROOF CAP,(IP67)     650.00
A6CVR-16     16 PTS. MODULE PROTECT COVER, (10 PCS)     500.00
A6CVR-32     32 PTS. MODULE PROTECT COVER, (10 PCS)     440.00
A6CVR-8     8 PTS. MODULE PROTECT COVER, (10 PCS)     420.00
A6FD     ASCII CHARACTER DISPLAY UNIT    7,940.00
A6RAF     BUS SWITCH MODULE     4,680.00
A6SW16     SIMULATION SWTICH : 16 INPUT POINT     770.00
A6SW32     SIMULATION SWITCH : 32 INPUT POINT     1,160.00
A6TBX36-E     36 PTS, SOURCE INPUT, APPLICABLE TO A1SX81     580.00
A6TBX54-E     54 PTS, SOURCE INPUT, APPLICABLE TO A1SX81     750.00
A6TBX70     70 PTS, SINK INPUT, APPLICABLE TO A1SX41/42     890.00
A6TBX70-E     70 PTS, SOURCE INPUT, APPLICABLE TO A1SX81     890.00
A6TBXY36     36 PTS, SINK, APPLICABLE TO A1SX41/42 & A1SY41/42     580.00
A6TBXY54     54 PTS, SINK, APPLICABLE TO A1SX41/42 & A1SY41/42     750.00
A6TBY36-E     36 PTS, SOURCE OUTPUT, APPLICABLE TO A1SY81    580.00
A6TBY54-E     54 PTS, SOURCE OUTPUT, APPLICABLE TO A1SY81    750.00
A6TE2-16SRN     16 PTS, RELAY OUTPUT UNIT, APPLICABLE TO A1SY41/42    1,620.00
A6WA-28P     READ/WRITE ADAPTER FOR A1SMCA-8KP     420.00
AC05TB     0.5 M CABLE, SINK TYPE, APPLICABLE TO A6TB( )     500.00
AC06B     0.6M BUS CONNECTION (A/QnA CPU & A7GT-CNB)     790.00
AC06TE     0.6 M CABLE FOR A6TE2-16SR    460.00
AC100R4-25P     10M RS422 CABLE FOR CPU CONNECTION (AnS/A/QnA/QnAS/FX2)     2,760.00
AC100TE     10 M CABLE FOR A6TE2-16SR     1,100.00
AC10TB    1 M CABLE, SINK TYPE, APPLICABLE TO A6TB( )     530.00
AC10TE     1 M CABLE FOR A6TE2-16SR    440.00
AC12B     1.2M BUS CONNECTION (A/QnA CPU & A7GT-CNB)     1,200.00
AC12B-R    1.2M RIGHT-ANGELD BUS CONNECTION (A/QnA CPU & A7GT-CNB)     1,380.00
AC12MX    CONNECTION CABLE FOR MULTIPLEXER UNIT (1.2m LONG)     970.00
AC20R4-A8PU     CONNECTION CABLE BETWEEN A8PU AND CPU, 2m LONG     1,340.00
AC20TB     2 M CABLE, SINK TYPE, APPLICABLE TO A6TB( )     580.00
AC300PIO-20P     30M PRINTER CONNECTION     3,310.00
AC300R4     RS422 CABLE BETWEEN THE GPP AND CPU, 30m LONG     4,080.00
AC300R4-25P     30M RS422 CABLE FOR CPU CONNECTION (AnS/A/QnA/QnAS/FX2)     4,610.00
AC30B    3M BUS CONNECTION (A/QnA CPU & A7GT-CNB)     1,600.00
AC30B-R     3M RIGHT-ANGELD BUS CONNECTION (A/QnA CPU & A7GT-CNB)     1,860.00
AC30PIO-20P     3M PRINTER CONNECTION     1,380.00
AC30R2     RS232 CABLE BETWEEN GPPAND SERIAL PRINTER, 3m LONG    2,120.00
AC30R2-9P     3M DATA TRANSFER CABLE (D-SUB 9 PIN/25 PIN)     1,620.00
AC30R2-9SS     3M DATA TRANSFER CABLE (D-SUB 9 PIN/9 PIN)     1,620.00
AC30R4     RS422 CABLE BETWEEN THE GPP AND CPU, 3m LONG     1,420.00
AC30R4-25P     3M RS422 CABLE FOR CPU CONNECTION (AnS/A/QnA/QnAS/FX2)     1,860.00
AC30R4-PUS     A7PU CABLE, 3 M LONG     1,660.00
AC30TB    3 M CABLE, SINK TYPE, APPLICABLE TO A6TB( )     640.00
AC30TE     3 M CABLE FOR A6TE2-16SR     660.00
AC50B    5M BUS CONNECTION (A/QnA CPU & A7GT-CNB)     1,990.00
AC50B-R     5M RIGHT-ANGELD BUS CONNECTION (A/QnA CPU & A7GT-CNB)     2,310.00
AC50TB    5 M CABLE, SINK TYPE, APPLICABLE TO A6TB( )     750.00
AC50TE     5 M CABLE FOR A6TE2-16SR     660.00
AD51H-S3    AD51H-BASIC, 2 X RS422, 1 X RS232, 1 X PARALLEL     28,330.00
AD61     HIGH SPEED COUNTER : 2 CH., 50KPPS(1/2 PHASE)     7,200.00
AD61S1     HIGH SPEED COUNTER : 2 CH. , 10KPPS/1 PHASE, 7KPPS/2 PHASES    7,200.00
AD71-S2     POSITIONING CONTROL : 2 AXES, PULSE TRAIN OUTPUT     15,370.00
AD71TU     TEACHING UNIT FOR AD71/72     8,100.00
AD72     POSITIONING CONTROL : 2 AXES, ANALOG OUTPUT    20,230.00
AD75P1-S3    PULSE TRAIN O/P, 1 AXIS     7,600.00
AD75P2-S3    PULSE TRAIN O/P, 2 AXES     11,990.00
AD75P3-S3     PULSE TRAIN O/P, 3 AXES     16,000.00
AD75TU     AD75 TEACHING PANEL     7,550.00
AG60     BLANK UNIT     160.00
AG62     DUMMY UNIT : 16/32/48/64 POINT SELECTABLE     1,130.00
AH42     32 PT. INPUT, 32 PT. SINK OUTPUT, DC 12/24V     5,340.00
AI61     16 PT. INTERRUPT MODULE     4,610.00
AJ55TB2-16R     REMOTE OUTPUT, 16 PTS, RELAY, AC240V 2A/PT.     3,530.00
AJ55TB2-16T     REMOTE OUTPUT, 16 PTS, TRANSISTOR(SINK), DC24V 0.5A/PT.     2,870.00
AJ55TB2-4R     REMOTE OUTPUT, 4 PTS, RELAY, AC240V 2A/PT.     1,850.00
AJ55TB2-4T    REMOTE OUTPUT, 4 PTS, TRANSISTOR(SINK), DC24V 0.5A/PT.     1,790.00
AJ55TB2-8R     REMOTE OUTPUT, 8 PTS, RELAY, AC240V 2A/PT.     2,160.00
AJ55TB2-8T     REMOTE OUTPUT, 8 PTS, TRANSISTOR(SINK), DC24V 0.5A/PT.     2,010.00
AJ55TB3-16D     REMOTE INPUT, 16 PTS, DC24V     2,870.00
AJ55TB32-16DR     INPUT 8 PTS, DC24V / OUTPUT 8 PTS, RELAY AC240V 2A/PT.     3,080.00
AJ55TB32-16DT     INPUT 8 PTS, DC24V / OUTPUT 8 PTS, TRAN.(SINK) DC24V 0.5A/PT.     2,870.00
AJ55TB32-4DR     INPUT 2 PTS, DC24V / OUTPUT 2 PTS, RELAY AC240V 2A/PT.     1,790.00
AJ55TB32-4DT     INPUT 2 PTS, DC24V / OUTPUT 2 PTS, TRAN.(SINK) DC24V 0.5A/PT.     1,850.00
AJ55TB32-8DR     INPUT 4 PTS, DC24V / OUTPUT 4 PTS, RELAY AC240V 2A/PT.     2,010.00
AJ55TB32-8DT     INPUT 4 PTS, DC24V / OUTPUT 4 PTS, TRAN.(SINK) DC24V 0.5A/PT.     1,940.00
AJ55TB3-4D    REMOTE INPUT, 4 PTS, DC24V     1,700.00
AJ55TB3-8D    REMOTE INPUT, 8 PTS, DC24V     1,940.00
AJ61BT11     MASTER/LOCAL MODULE FOR ACPU     5,880.00
AJ61QBT11     CC-LINK MASTER     5,880.00
AJ65BT-64AD     4CH. A/D CONVERSION MODULE     7,550.00
AJ65BT-64DAI     4 CH. D/A CONVERSION MODULE, CURRENT OUTPUT    10,080.00
AJ65BT-64DAV     4 CH. D/A CONVERSION MODULE     10,080.00
AJ65BT-64RD3     4 CH. PT100(3-WIRE TYPE) TEMPERATURE INPUT MODULE     11,750.00
AJ65BT-64RD4     4 CH. PT100(4-WIRE TYPE) TEMPERATURE INPUT MODULE     11,750.00
AJ65BT-68TD     8 CH. THERMOCOUPLE TEMPERATURE INPUT MODULE     16,790.00
AJ65BTB1-16D     16PTS. IN, 24VDC(5MA)     3,280.00
AJ65BTB1-16DT     8PTS. INPUT, 24VDC(7MA); 8PTS. TRAN. OUTPUT, 24VDC(0.5A)     3,530.00
AJ65BTB1-16T     16PTS. TRANSISTOR OUTPUT, 24VDC(0.5A),     3,360.00
AJ65BTB2-16D     16PTS. IN, 24VDC(7MA)     3,530.00
AJ65BTB2-16DR     8PTS. INPUT, 8PTS. RELAY OUTPUT, 24VDC/240VAC(2A)     4,020.00
AJ65BTB2-16DT     8PTS. INPUT, 8PTS. TRAN. OUTPUT, 24VDC(0.5A)     3,700.00
AJ65BTB2-16R     16PTS. RELAY OUTPUT, 24VDC/240VAC(2A),     4,270.00
AJ65BTB2-16T     16PTS. TRANSISTOR OUTPUT, 24VDC(0.5A),     3,530.00
AJ65BTC1-32D     32PTS. IN, 24VDC(7MA)     4,120.00
AJ65BTC1-32T     32PTS. TRANSISTOR OUTPUT, 24VDC(0.1A),     4,370.00
AJ65BT-D62     HIGH SPEED COUNTER, DC INPUT, PRESET DC INPUT     7,480.00
AJ65BT-D62D     HIGH SPEED COUNTER, DIFF. INPUT, PRESET DC INPUT     7,480.00
AJ65BT-D62D-S1     HIGH SPEED COUNTER, DIFF. INPUT, PRESET DIFF. INPUT    7,480.00
AJ65BT-D75P2-S3     2 AXES POSITIONING MODULE     10,110.00
AJ65BT-G4-S3     GPP FUNCTION PERIPHERAL CONNECTION UNIT     7,550.00
AJ65BT-R2     RS-232C INTERFACE MODULE    7,550.00
AJ65BT-RPI-10A     CC-LINK SPATIAL OPTIC REPEATER    8,380.00
AJ65BT-RPI-10B     CC-LINK SPATIAL OPTICA REPEATER     8,380.00
AJ65FBTA2-16T    16PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), TWO WIRE TYPE     5,130.00
AJ65FBTA2-16TE     16PTS. 1A TRANSISTOR OUTPUT (SOURCE TYPE), TWO WIRE TYPE     5,610.00
AJ65FBTA4-16D     16PTS. DC SINK INPUT, SINK TYPE, FOUR WIRE TYPE    5,130.00
AJ65FBTA4-16DE     16PTS. DC SINK INPUT, SOURCE TYPE, FOUR WIRE TYPE     5,130.00
AJ65FBTA42-16DT     8PTS. DC SINK INPUT, TRANSISTOR OUTPUT (SINK TYPE)     5,130.00
AJ65FBTA42-16DTE     8PTS. DC SINK INPUT, TRANSISTOR OUTPUT (SOURCE TYPE)     5,610.00
AJ65MBTL1N-16D     16PTS. DC+COM INPUT, EMBEDDED TYPE 44 PINS (2 ROWS)     2,050.00
AJ65MBTL1N-16D    T 8PTS. INPUT,TRAN. OUTPUT, EMBEDDED TYPE 44 PINS (2 ROWS)     2,050.00
AJ65MBTL1N-16T     16PTS. 0.1A TRAN. OUTPUT, EMBEDDED TYPE 44 PINS (2 ROWS)     2,050.00
AJ65MBTL1N-32D     32PTS. DC+COM INPUT, EMBEDDED TYPE 62 PINS (2 ROWS)     3,400.00
AJ65MBTL1N-32T     32PTS. 0.1A TRAN. OUTPUT, EMBEDDED TYPE 62 PINS (2 ROWS)     3,500.00
AJ65SBT-62DA     2CH. D/A CONVERSION MODULE    5,350.00
AJ65SBT-64AD     4CH. A/D CONVERSION MODULE     4,990.00
AJ65SBTB1-16D     16PTS. INPUT, 24VDC(7MA)    2,160.00
AJ65SBTB1-16D1     16PTS. INPUT, 24VDC(5MA), 0.2MS RESPONSE     2,310.00
AJ65SBTB1-16DT     8PTS. INPUT/TRANS. OUTPUT (SINK TYPE)     2,400.00
AJ65SBTB1-16DT1     8PTS. INPUT/TRANS. OUTPUT (SINK TYPE), HIGH SPEED RESPOND     2,570.00
AJ65SBTB1-16DT2     8PTS. INPUT/TRANS. OUTPUT (SINK TYPE), LOW LEAKAGE     2,520.00
AJ65SBTB1-16DT3     8PTS. INPUT/TRANS. OUTPUT (SINK TYPE), HIGH SPEED/LOW LEAK.     2,560.00
AJ65SBTB1-16T     16PTS. TRANSISTOR OUTPUT, 24VDC(0.5A)     2,160.00
AJ65SBTB1-16T1     16PTS. TRANSISTOR OUTPUT, 24VDC(0.1A)     2,160.00
AJ65SBTB1-16TE     16PTS. TRANSISTOR OUTPUT, (SOURCE TYPE), ONE WIRE TYPE     2,520.00
AJ65SBTB1-32D     32PTS. INPUT, 24VDC(7MA)     3,630.00
AJ65SBTB1-32D1     32PTS. INPUT, 24VDC(5MA), RESPONSE TIME 0.2MS     3,860.00
AJ65SBTB1-32DT    16PTS. IN,24VDC(0.5MA), TRANSISTOR OUT (SINK TYPE)     3,380.00
AJ65SBTB1-32DT1    16PTS. INPUT, TRANS. OUTPUT (SINK TYPE), HIGH SPEED RESPOND     4,150.00
AJ65SBTB1-32DT2     16PTS. INPUT, TRANS. OUTPUT (SINK TYPE), HIGH SPEED/LOW LEAK.     4,150.00
AJ65SBTB1-32DT3     16PTS. INPUT, TRANS. OUTPUT (SINK TYPE), LOW LEAKAGE    4,150.00
AJ65SBTB1-32T     32PTS. TRAN. OUT, 24VDC(0.5A)     3,630.00
AJ65SBTB1-32T1     32PTS. TRAN. OUT, 24VDC(0.1A)     3,640.00
AJ65SBTB1-8D     8PTS. INPUT, 24VDC(7MA)     1,840.00
AJ65SBTB1-8T     8PTS. TRANSISTOR OUTPUT, 12/24VDC(0.5A)     1,840.00
AJ65SBTB1-8T1     8PTS. TRANSISTOR OUTPUT, 12/24VDC(0.5A), LOW LEAKAGE     2,060.00
AJ65SBTB2-16T     16PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), TWO WIRE TYPE     2,800.00
AJ65SBTB2-16T1     16PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), LOW LEAKAGE     2,790.00
AJ65SBTB2-8T     8PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), TWO WIRE TYPE     2,330.00
AJ65SBTB2-8T1     8PTS. 0.5A TRANSISTOR OUTPUT (SINK TYPE), LOW LEAKAGE     1,400.00
AJ65SBTB2N-16A     16PTS., AC INPUT, TWO WIRE TYPE     2,710.00
AJ65SBTB2N-16R     16PTS. 24 VDC/240 VAC 2A, RELAY OUTPUT, TWO WIRE TYPE     3,300.00
AJ65SBTB2N-16S     16PTS. 0.6A TRIAC OUTPUT, TWO WIRE TYPE     4,960.00
AJ65SBTB2N-8A     8PTS., AC INPUT, TWO WIRE TYPE     2,240.00
AJ65SBTB2N-8R     8PTS. 24 VDC/240 VAC 2A, RELAY OUTPUT, TWO WIRE TYPE     2,520.00
AJ65SBTB2N-8S     8PTS. 0.6A TRIAC OUTPUT, TWO WIRE TYPE     3,280.00
AJ65SBTB3-16D     16PTS., DC SINK/SOURCE COMMON INPUT, THREE WIRE TYPE     2,800.00
AJ65SBTB32-16DT     8PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, 2 WIRE TYPE     2,800.00
AJ65SBTB32-16DT2     8PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, LOW LEAKAGE     1,680.00
AJ65SBTB32-8DT     4PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, 2 WIRE TYPE     2,330.00
AJ65SBTB32-8DT2     4PTS., DC SINK/IN, 3 WIRE TYPE, 0.5A TRAN. OUT, LOW LEAKAGE     2,330.00
AJ65SBTB3-8D     8PTS., DC SINK/SOURCE COMMON INPUT, THREE WIRE TYPE     2,330.00
AJ65SBTC1-32D     32PTS. INPUT, 24VDC(7MA)     3,560.00
AJ65SBTC1-32D1     32PTS. INPUT, 24VDC(7MA), 0.2MS RESPONSE     3,780.00
AJ65SBTC1-32DT     16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, 24VDC    3,560.00
AJ65SBTC1-32DT1     16PTS. IN,24VDC(0.5MA),16PTS. TRAN. OUT, 24VDC(0.1A)     3,780.00
AJ65SBTC1-32DT2     16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, 24VDC, LOW LEAKAGE     4,150.00
AJ65SBTC1-32DT3     16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, HIGH SPEED/LOW LEAK.     4,190.00
AJ65SBTC1-32T    32PTS. TRAN. OUT, 24VDC(0.1A)     3,560.00
AJ65SBTC1-32T1     32PTS. TRAN. OUT, 24VDC(0.1A), LOW LEAKAGE    4,150.00
AJ65SBTC4-16D     16PTS. INPUT, 24VDC(5MA)     2,180.00
AJ65SBTC4-16DT     8PTS., DC SINK/IN, 2, 3, 4 WIRE TYPE, 0.5A TRAN., OUT, 4 WIRE TYPE     2,180.00
AJ65SBTC4-16DT2     8PTS., DC SINK/IN, 2, 3, 4 WIRE TYPE, 0.5A TRAN., OUT, LOW LEAK.     2,560.00
AJ65SBTCF1-32D     32PTS. INPUT, 24VDC(7MA)     3,030.00
AJ65SBTCF1-32DT     16PTS. IN,24VDC(0.5MA), 16PTS. TRAN. OUT, 24VDC     3,030.00
AJ65SBTCF1-32T     32PTS. TRAN. OUT, 24VDC(0.5A),     3,030.00
AJ65SBT-RPS    CC-LINK OPTICAL REPEATER     3,410.00
AJ65SBT-RPT     CC-LINK REPEATER (T-BRANCH)     2,080.00
AJ65SBTW4-16D     16PTS. INPUT, 24VDC(5MA), WATER PROOF     5,040.00
AJ65SBTW4-16DT     8PTS. IN,24VDC/0.5MA, 8PTS. TRAN. OUT, 24VDC/0.5A, WATER PROOF    5,040.00
AJ65VBTCU68ADI    8 CH. A/D CURRENT INPUT CONVERSION MODULE     8,380.00
AJ65VBTCU68ADV     8 CH. A/D VOLTAGE INPUT CONVERSION MODULE     8,380.00
AJ65VBTCU68DAVN     8 CH. D/A CONVERSION MODULE    11,170.00
AJ71AP21     MELSECNET MASTER/LOCAL, OPTICAL LINK     12,140.00
AJ71AR21    MELSECNET MASTER/LOCAL, COAXIAL LINK     12,140.00
AJ71AT21B    MELSECNET/B MASTER/LOCAL    9,710.00
AJ71BR11    MELSECNET/10 MASTER/LOCAL, COAXIAL     14,490.00
AJ71C22-S1    MULTIDROP LINK UNIT     8,630.00
AJ71E71N-B2    ETHERNET INTERFACE UNIT, 10BASE2     20,000.00
AJ71E71N-B5T    ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5     20,000.00
AJ71LP21     MELSECNET/10 MASTER/LOCAL, SI-200/250 OPTICAL LINK     14,490.00
AJ71LP21G     MELSECNET/10 MASTER/LOCAL, GI-50/125 TYPE OPTICAL LINK     22,400.00
AJ71LP21GE     MELSECNET/10 MASTER/LOCAL, GI-62.5/125 TYPE OPTICAL LINK     14,400.00
AJ71PT32-S3     MELSECNET/MINI MASTER UNIT     9,980.00
AJ71QBR11     MELSECNET/10 , COAXIAL     13,610.00
AJ71QC24     RS232C &RS422 I/F     8,060.00
AJ71QC24N     RS232C &RS422 I/F(NEW TYPE)     8,620.00
AJ71QC24N-R2     RS232 I/F, 2 CH(NEW TYPE)     8,620.00
AJ71QC24N-R4     RS422 & RS422/485 I/F(NEW TYPE)     8,620.00
AJ71QC24-R2     RS232 I/F, 2 CH     8,060.00
AJ71QC24-R4     RS422 & RS422/485 I/F     8,060.00
AJ71QE71N-B2     ETHERNET INTERFACE UNIT, 10BASE2     18,890.00
AJ71QE71N-B5T     ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5     15,110.00
AJ71QLP21     MELSECNET/10 , SI-200/250 FIBRE OPTIC     13,610.00
AJ71QLP21G     MELSECNET/10 , GI-50/125 TYPE FIBRE OPTIC     21,160.00
AJ71QLP21S     MELSECNET/10 , SI-200/250 FIBRE OPTIC, EXT POWER    18,120.00
AJ71UC24    COMPUTER LINK UNIT     13,670.00
AJ71UC24-S2    RS232/RS422/485 MODBUS PROTOCOL MODULE     13,500.00
AJ72P25     MELSECNET REMOTE I/O CONTROLLER, OPTICAL LINK    14,560.00
AJ72QBR15     MELSECNET/10 REMOTE I/O CONTROLLER, COAXIAL     13,610.00
AJ72QLP25     MELSECNET/10 REMOTE I/O CONTROLLER, SI FIBRE OPOTIC     21,160.00
AJ72QLP25G     MELSECNET/10 REMOTE I/O CONTROLLER, GI FIBRE OPOTIC     21,160.00
AJ72R25     MELSECNET REMOTE I/O CONTROLLER, COAXIAL LINK    14,560.00
AJ72T25B    MELSECNET/B REMOTE STATION     9,710.00
AS91     SYSTEM FAULT DETECTION MODULE     2,730.00
AS91    SYSTEM MONITOR MODULE     2,800.00
AS92R     SYSTEM FAULT DETECTION MODULE     3,910.00
AX10     16 PTS. AC 100V, 10mA     2,840.00
AX11     32 PTS. AC 100V, 10mA    4,940.00
AX20    16 PT. AC 200V, 10mA     3,400.00
AX21     32 PT. AC 200V, 10mA     5,670.00
AX40     16 PT. DC 12/24V, SINK INPUT (4/10mA)     2,670.00
AX41     32 PT. DC 12/24V, SINK INPUT (4/10mA)     4,210.00
AX41-S1     32 PT. DC 12/24V, SINK INPUT (4/10mA), FAST RESPONSE    4,370.00
AX42     64 PT. DC 12/24V, SINK INPUT (3/7mA)     5,260.00
AX42-S1     64 PT. DC 12/24V, SINK INPUT (3/7mA), FAST RESPONSE     5,500.00
AX50-S1     16 PT. DC 48V, SINK/SOURCE (4mA)     2,890.00
AX60-S1     16 PT. DC 100/110/125V, SINK/SOURCE (2mA)     3,540.00
AX70     16 PT. DC 5/12/24V, SINK/SOURCE INPUT (2mA)     2,750.00
AX71     32 PT. DC 5/12/24V, SINK/SOURCE INPUT (3.5/2/4.5mA)     4,040.00
AX80     16 PT. DC 12/24V, SOURCE INPUT (4/10mA)     3,230.00
AX80E     16 PT. DC 12/24V, SOURCE INPUT (4/10mA), FAST RESPONSE     3,400.00
AX81    32 PT. DC 12/24V, SOURCE INPUT (4/10mA)     4,040.00
AX82     64 PT. DC 12/24V, SOURCE INPUT (8/7mA)     5,670.00
AY10     16 PT. RELAY OUTPUT, 2A     2,990.00
AY10A     16 PT. RELAY OUTPUT, 2A (INDEPENDENT COMMONS)     3,230.00
AY11     16 PT. RELAY OUTPUT, 2A     3,480.00
AY11A     16 PT. RELAY OUTPUT2A (INDEPENDENT COMMONS)     3,800.00
AY11E     16 PT. RELAY OUTPUT 2A (FUSED COMMON)     3,640.00
AY13    32 PT. RELAY OUTPUT 2A    5,500.00
AY13E    32 PT. RELAY OUTPUT 2A (FUSED COMMON)     6,550.00
AY22     16 PT. TRIAC OUTPUT 2A 4,     130.00
AY23    32 PT. TRIAC OUTPUT 0.6A     6,880.00
AY40    16 PT. DC 12/24V TRANSISTOR SINK OUTPUT 0.1A     3,080.00
AY40A    16 PT. DC 12/24V TRANSISTOR SINK OUTPUT 0.3A ( INDEPENDENT)     3,560.00
AY40P     16 PT. DC 12/24V TRANSISTOR SINK 0.1A (SHORT CCT. PROTECTION)     3,080.00
AY41     32 PT. DC 12/24V TRANSISTOR SINK 0.1A    3,890.00
AY41P     16 PT. DC 12/24V TRANSISTOR SINK 0.1A (SHORT CCT. PROTECTION)     3,890.00
AY42     64 PT. DC 12/24V TRANSISTOR SINK 0.1A     5,430.00
AY42-S1     64 PT. DC 12/24V TRANSISTOR SINK 0.1A (HIGH SPEED)     5,670.00
AY42-S3     64 PT. DC 12/24V TRANSISTOR SINK 0.1A (FUSED)     5,670.00
AY50    16 PT. DC 12/24V TRANSISTOR SINK 0.5A     3,400.00
AY51     32 PT. DC 12/24V TRANSISTOR SINK 0.5A     4,450.00
AY51-S1     32 PT., DC 12/24V TRANSISTOR SINK 0.3A    4,860.00
AY60     16 PT. DC 12/24/48V TRANSISTOR SOURCE 2A     3,890.00
AY60E     16 PT. DC 12/24/48V TRANSISTOR SOURCE 0.5A     4,450.00
AY60S     16 PT. DC 24/48V TRANSISTOR SINK FOR TTL & CMOS, 2A     5,370.00
AY70     16 PT. DC5/12V TRANSISTOR SINK FOR TTL & CMOS 16mA     2,840.00
AY71     32 PT. DC5/12V TRANSISTOR SINK FOR TTL & CMOS 16mA     3,730.00
AY72     64 PT. DC 5/12V TRANSISTOR SINK FOR TTL & CMOS, 16mA    5,500.00
AY80     16 PT. DC 12/24V TRANSISTOR SOURCE OUTPUT, 0.5A    3,890.00
AY81     32 PT. DC 12/24V TRANSISTOR SOURCE, 0.5A     5,260.00
AY81EP     32 PT. DC 12/24V TRANSISTOR SOURCE, 0.8A WITH SHORT CIRCUIT PROTECTION    7,310.00
AY82EP     64 PT. DC 12/24V TRANSISTOR SOURCE, 0.1A, WITH SHORT CIRCUIT PROTECTION    7,200.00
价格面议,量大从优。
深圳市菱泰兴科技有限公司
电话:0755-86368150
传真:0755-86369202
联系人:刘生
手机:13267152530
yangbo-7788
查看yangbo-7788的 主题 / 回贴
1楼  发表于: 2007-11-20 18:57
有没有打折嘛
jq_2007
发帖数量: 95 个
工控威望: 1300 点
下载积分: 552 分
在线时间: 161(小时)
查看jq_2007的 主题 / 回贴
2楼  发表于: 2008-08-19 14:51
有没有相关说明书
