qq240559043
干就完了
发帖数量: 201 个
工控威望: 345 点
下载积分: 4340 分
在线时间: 151(小时)
查看qq240559043的 主题 / 回贴
楼主  发表于: 2022-02-24 08:21
if ModeB_Aerate == true then
   StringGet(QR[0], "OMRON EtherNet/IP (NJ/NX Series)", "VAR://气密性二维码[0]", 20)                       //验证读PLC存储的二维码
   //StringGet(QR[0], "Local HMI", LW, 100, 10)
   GetData(ModeB_AerateOK, "OMRON EtherNet/IP (NJ/NX Series)", "VAR://充气完成提示", 1)
   GetData(ModeB_AerateNG, "OMRON EtherNet/IP (NJ/NX Series)", "VAR://AL充气超时", 1)
   if Formula_Count >= Formula_Limit then
      SetData(zero, "Local HMI", RECIPE, "DATA1.Count") //选中第一个数据
      SetData(Formula_Delete, "Local HMI", RECIPE, "DATA1.Command") //删除选中数据
   end if
[ 此帖被qq240559043在2022-02-26 13:38重新编辑 ]
