xiaobao21
发帖数量: 345 个
工控威望: 505 点
下载积分: 8183 分
在线时间: 113(小时)
查看xiaobao21的 主题 / 回贴
楼主  发表于: 2014-11-25 11:35
如题,有些命令不明白,比如SAVE,TAK,TAR2,UC “RD_REC”,P#L22.2,L DINO,LAR2 LD36,L PID [AR1,P#0.0]等等,希望哪位老师能结合上下段给我详细解释一下,非常感激,再次感谢!
STL程序如下:
      SET
      SAVE
      =     L     22.1
      L     0
      T     #TEMP122
      CLR
      =     #TEMP119
      A     #IO45
      O     #STAT94
      JCN   M001
      SET
      =     #STAT94
      =     #STAT96
      =     #STAT95
      L     0.000000e+000
      T     #OUT6
      T     #OUT9
      L     #IN1
      L     189
      +I
      AW    W#16#FF
      T     #TEMP121
      L     #IN0
      T     LW    24
      =     L     22.2
      L     B#16#54
      T     LB    23
      L     DW#16#1002004E
      T     LD    26
      L     DINO
      T     LW    30
      TAR2
      +     L#560
      T     LD    32
      TAR2  LD    36
      UC    "RD_REC"
            P#L 22.2
            P#L 23.0
            P#L 24.0
            P#L 11.0
            P#L 12.0
            P#L 10.0
            P#L 26.0
      LAR2  LD    36
      JU    M002
M001: CLR
      A     #IO48
      JCN   M002
      L     #IN1
      L     169
      +I
      AW    W#16#FF
      T     #TEMP121
      L     #IN0
      T     LW    24
      SET
      =     L     22.2
      L     B#16#54
      T     LB    23
      L     DW#16#1002004E
      T     LD    26
      L     DINO
      T     LW    30
      TAR2
      +     L#560
      T     LD    32
      TAR2  LD    36
      UC    "WR_REC"
            P#L 22.2
            P#L 23.0
            P#L 24.0
            P#L 11.0
            P#L 26.0
            P#L 12.0
            P#L 10.0
      LAR2  LD    36
M002: L     #TEMP122
      T     #OUT3
      L     0
      <I
      =     #TEMP120
      NOT
      =     L     22.2
      A     #TEMP119
      NOT
      A     L     22.2
      JCN   M003
      A     #IO45
      O     #STAT94
      JCN   M004
      CLR
      =     #IO45
      =     #STAT94
      JU    M003
M004: CLR
      =     #IO48
M003: CLR
      A     #STAT94
      NOT
      JCN   M005
      L     #IN1
      L     1
      -I
      L     4
      *I
      L     #IN0
      +I
      T     #TEMP118
      ITD
      L     L#8
      *D
      LAR1
      L     PID [AR1,P#0.0]
      T     LD     0
      A     #IO47
      O     #IO46
      JCN   M006
      SET
      =     #STAT95
      L     #IN1
      L     129
      +I
      AW    W#16#FF
      T     #TEMP121
      L     #IN0
      T     LW    24
      =     L     22.2
      L     B#16#54
      T     LB    23
      L     DW#16#10020022
      T     LD    26
      L     DINO
      T     LW    30
      TAR2
      +     L#64
      T     LD    32
      TAR2  LD    36
      UC    "RD_REC"
            P#L 22.2
            P#L 23.0
            P#L 24.0
            P#L 11.0
            P#L 12.0
            P#L 10.0
            P#L 26.0
      LAR2  LD    36
      A     #TEMP120
      NOT
      JCN   M007
      L     #TEMP122
      T     #OUT3
M007: L     #TEMP122
      L     0
      <I
      JCN   M008
      SET
      =     #TEMP120
      JU    M009
M008: CLR
      A     #TEMP119
      NOT
      JCN   M00a
      CLR
      =     #IO47
      A     #OUT43
      JCN   M00a
      A     #OUT28
      =     #IO52
      A     #OUT30
      =     #IO54
      L     #OUT5
      T     #IO65
      L     #OUT9
      T     #IO66
M00a: JU    M009
M006: CLR
      A     #TEMP99.TEMP115
      JCN   M00b
      L     #TEMP99.TEMP100
      T     #STAT98
      CLR
      =     #STAT95
      JU    M00c
M00b: CLR
      A     #STAT95
      NOT
      JCN   M00c
      L     #STAT98
      T     LW     6
      L     #TEMP99.TEMP100
      T     LW     4
      A     #TEMP99.TEMP116
      JCN   M00d
      L     #TEMP117
      T     #OUT9
      JU    M00e
M00d: L     #TEMP117
      T     #OUT6
M00e: CLR
      A     #TEMP99.TEMP116
      NOT
      =     #STAT91
M00c: CLR
      A     #TEMP99.TEMP116
      JCN   M00f
      A     #TEMP99.TEMP101
      =     #OUT28
      A     #TEMP99.TEMP102
      =     #OUT29
      A     #TEMP99.TEMP103
      =     #OUT30
      A     #TEMP99.TEMP104
      =     #OUT31
      A     #TEMP99.TEMP105
      =     #OUT32
      A     #TEMP99.TEMP106
      =     #OUT33
      A     #TEMP99.TEMP107
      =     #OUT34
      A     #TEMP99.TEMP108
      =     #OUT35
      A     #TEMP99.TEMP109
      =     #OUT36
      A     #TEMP99.TEMP110
      =     #OUT37
      A     #TEMP99.TEMP111
      =     #OUT38
      A     #TEMP99.TEMP112
      =     #OUT26
      A     #TEMP99.TEMP113
      =     #OUT40
      JU    M009
M00f: CLR
      A     #TEMP99.TEMP101
      =     #OUT12
      A     #TEMP99.TEMP102
      =     #OUT13
      A     #TEMP99.TEMP103
      =     #OUT14
      A     #TEMP99.TEMP104
      =     #OUT15
      A     #TEMP99.TEMP105
      =     #OUT16
      A     #TEMP99.TEMP106
      =     #OUT17
      A     #TEMP99.TEMP107
      =     #OUT18
      A     #TEMP99.TEMP108
      =     #OUT19
      A     #TEMP99.TEMP109
      =     #OUT20
      A     #TEMP99.TEMP110
      =     #OUT21
      A     #TEMP99.TEMP111
      =     #OUT22
      A     #TEMP99.TEMP112
      =     #OUT23
      A     #TEMP99.TEMP113
      =     #OUT24
      A     #TEMP99.TEMP114
      =     #OUT25
M009: CLR
      A     #IO46
      JCN   M010
      SET
      =     #STAT96
      L     #IN1
      L     189
      +I
      AW    W#16#FF
      T     #TEMP121
      L     W#16#3130
      T     #IO49
      L     #IN0
      T     LW    24
      =     L     22.2
      L     B#16#54
      T     LB    23
      L     DW#16#10020018
      T     LD    26
      L     DINO
      T     LW    30
      TAR2
      +     L#368
      T     LD    32
      TAR2  LD    36
      UC    "WR_REC"
            P#L 22.2
            P#L 23.0
            P#L 24.0
            P#L 11.0
            P#L 26.0
            P#L 12.0
            P#L 10.0
      LAR2  LD    36
      L     #TEMP122
      L     0
      >=I
      =     L     22.2
      A     #TEMP119
      NOT
      A     L     22.2
      JCN   M011
      CLR
      =     #IO46
      JU    M012
M011: CLR
      A     #TEMP120
      NOT
      JCN   M005
      L     #TEMP122
      T     #OUT3
M012: JU    M005
M010: CLR
      A     #STAT96
      JCN   M013
      SET
      =     #STAT92
      CLR
      =     #STAT96
      JU    M014
M013: CLR
      A     #TEMP99.TEMP115
      NOT
      =     #STAT92
M014: CLR
      A     #STAT92
      NOT
      JCN   M015
      L     #STAT97
      T     #TEMP99.TEMP100
      JU    M016
M015: CLR
      A     #STAT93
      NOT
      A     #IO63
      JCN   M017
      L     #IO67
      T     #TEMP117
      JU    M018
M017: CLR
      A     #IO54
      JCN   M019
      L     #IO66
      T     #TEMP117
      JU    M018
M019: CLR
      A     #IO56
      JCN   M01a
      L     #IO51
      T     #TEMP117
      JU    M018
M01a: CLR
      A     #IO52
      JCN   M01b
      L     #IO65
      T     #TEMP117
      JU    M018
M01b: L     #IO50
      T     #TEMP117
M018: L     LW     4
      T     #STAT97
      L     LW     6
      T     #TEMP99.TEMP100
      CLR
      A     #IO63
      =     #STAT93
M016: CLR
      A     #IO52
      =     #TEMP99.TEMP101
      A     #IO53
      =     #TEMP99.TEMP102
      A     #IO54
      =     #TEMP99.TEMP103
      A     #IO55
      =     #TEMP99.TEMP104
      A     #IO56
      =     #TEMP99.TEMP105
      A     #IO57
      =     #TEMP99.TEMP106
      A     #IO58
      =     #TEMP99.TEMP107
      A     #IO59
      =     #TEMP99.TEMP108
      A     #IO60
      =     #TEMP99.TEMP109
      A     #IO61
      =     #TEMP99.TEMP110
      A     #IO64
      =     #TEMP99.TEMP113
      A     #IO63
      =     #TEMP99.TEMP112
      A     #STAT92
      =     #TEMP99.TEMP115
      A     #STAT91
      =     #TEMP99.TEMP116
      L     #TEMP118
      ITD
      L     L#8
      *D
      L     LD     0
      TAK
      LAR1
      TAK
      T     PQD [AR1,P#0.0]
M005: L     #OUT3
      L     W#16#8000
      AW
      L     W#16#8000
      ==I
      =     #OUT44
      A     #OUT44
      O     #OUT18
      JCN   M01c
      SET
      =     #OUT19
M01c: CLR
      A     L     22.1
      SAVE
      BE
shanhe1375
发帖数量: 10 个
工控威望: 134 点
下载积分: 926 分
在线时间: 30(小时)
查看shanhe1375的 主题 / 回贴
1楼  发表于: 2014-11-25 13:05
[ 此帖被shanhe1375在2019-06-30 20:22重新编辑 ]
xiaobao21
发帖数量: 345 个
工控威望: 505 点
下载积分: 8183 分
在线时间: 113(小时)
2楼  发表于: 2014-11-25 13:57
呵呵,是啊,等专家
uploader
发帖数量: 216 个
工控威望: 3102 点
下载积分: 18562 分
在线时间: 253(小时)
查看uploader的 主题 / 回贴
3楼  发表于: 2014-11-25 16:24
这么长的程序,要翻译,呵呵。等专家出马了。
xiaobao21
发帖数量: 345 个
工控威望: 505 点
下载积分: 8183 分
在线时间: 113(小时)
4楼  发表于: 2014-11-26 13:15
结合上下段程序,主要给我解释一下这几句的含义就行了,SAVE,TAK,TAR2,UC “RD_REC”,P#L22.2,L DINO,LAR2 LD36,L PID [AR1,P#0.0]
mhbxfys
趁年轻,走遍中国!
发帖数量: 653 个
工控威望: 7029 点
下载积分: 7919 分
在线时间: 236(小时)
查看mhbxfys的 主题 / 回贴
5楼  发表于: 2014-12-01 09:38
不如自己去查查!
感谢每位朋友! 承接plc柜、电气柜设计、定制。触摸屏组态、调试。 蓝海华腾变频器代理,变频器维修!!!   QQ:545636511
