she012916
查看she012916的 主题 / 回贴
楼主  发表于: 2008-09-02 15:37
三菱所有FX系列PLC的技术资料
1 Alpha Controller
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_1.pdf
2 Alpha Hardware Manual
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_2.pdf
3 Alpha Programming Manual
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_3.pdf
4 Connection of FX2N-10GM,FX2N-20GM and peripherals
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_4.pdf
5 E-20TP-E SUPPLEMENTARY MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_5.pdf
6 F2-232-Cab接线图
7 FX COMMUNICATION USER'S MANUAL(RS-232C,RS-485 Detailed Commun
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_7.pdf
8 FX INPUT AND OUTPUT TERMINAL BLOCKS USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_8.pdf
9 FX Programming Manual I
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_9.pdf
10 FX,FX0N-485ADP USER'S GUIDE(Communication Adapter)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_10.pdf
11 FX0-10LDR User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_11.pdf
12 FX0N-232ADP USER'S GUIDE(Communication Adapter)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_12.pdf
13 FX0N-32NT-DP USER'S MANUAL(PROFIBUS-DP Interface Unit)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_13.pdf
14 FX0N-3A User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_14.pdf
15 FX0N-485ADP
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_15.pdf
16 FX-10-20GM-PROM
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_16.pdf
17 FX-10DM
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_17.pdf
18 FX-10DM-E User's Manual
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_18.pdf
19 FX1N HARDWARE MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_19.pdf
20 FX1N User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_20.pdf
21 FX1N-1DA-BD USER'S MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_21.pdf
22 FX1N-232BD
23 FX1N-232-BD User's Guide
24 FX1N-232-BD USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_22_23_24.pdf
25 FX1N-2AD-BD USER'S MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_25.pdf
26 FX1N-2EYT-BD USER'S MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_26.pdf
27 FX1N-422-BD USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_27.pdf
28 FX1N-485-BD USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_28.pdf
29 FX1N-4EX-BD USER'S MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_29.pdf
30 FX1N-5DM
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_30.pdf
31 FX1N-8AV-BD USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_31.pdf
32 FX1N-CNV-BD User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_32.pdf
33 FX1S FX1N Interrupt Pointer issue
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_33.doc
34 FX1S HARDWARE MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_34.pdf
35 FX1S Timer 63 issue
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_35.doc
36 FX1S User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_36.pdf
37 FX1S-N-2N-2NC-PROG-MANUAL-II
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_37.pdf
38 FX2N HARDWARE MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_38.pdf
39 FX2N Simulation Input Switches User's Guide
40 FX2N SIMULATION INPUT SWITCHES USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_39_40.pdf
41 FX2N,FX-1PG-E USER'S MANUAL(PULSE GENERATOR BLOCK)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_41.pdf
42 FX2N-10GM USER'S GUIDE(1 AXES POSITIONING CONTROLLER)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_42.pdf
43 FX2N-10GM,FX2N-20GM HARDWARE,PROGRAMMING MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_43.pdf
44 FX2N-10PG INSTALLATION MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_44.pdf
45 FX2N-10PG USER'S MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_45.pdf
46 FX2N-16CCL-M
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_46.pdf
47 FX2N-16CCL-M HARDWARE MANUALl
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_47.pdf
48 FX2N-16CCL-M UAER'S MANUAL
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_48.pdf
49 FX2N-16LNK-M USER'S MANUAL(REMOTE I & O SYSTEM Master Block)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_49.pdf
50 FX2N-1HC USER'S GUIDE(HIGH-SPEED COUNTER BLOCK)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_50.pdf
51 FX2N-1PG User's Manual
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_51.pdf
52 FX2N-1RM User's Manual
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_52.pdf
53 FX2N-1RM-E-SET USER'S MANUAL(PROGRAMMABLE CAM SWITCH UNIT)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_53.pdf
54 FX2N-20GM USER'S GUIDE(2 AXES POSITIONING CONTROLLER)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_54.pdf
55 FX2N-20PSU User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_55.pdf
56 FX2N-232-BD USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_56.pdf
57 FX2N-232IF HARDWARE MANUAL(RS-232C Communication Special Func
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_57.pdf
58 FX2N-2AD USER'S GUIDE(2CH INPUT-ANALOG SPECIAL FUNCTION BLOCK
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_58.pdf
59 FX2N-2DA USER'S GUIDE(2CH OUTPUT-ANALOG SPECIAL FUNCTION BLOC
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_59.pdf
60 FX2N-2LC USER'S MANUAL(2CH TEMPERATURE CONTROL BLOCK)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_60.pdf
61 FX2N-32ASI-M USER'S MANUAL(AS-i Interface Master Block)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_61.pdf
62 FX2N-32ASI-M-AS
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_62.pdf
63 FX2N-32CCL User's Manual (CC-Link Communication Special Funct
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_63.pdf
64 FX2N-32DP-IF
65 FX2N-32DP-IF HARDWARE MANUAL(PROFIBUS-DP Interface Unit)
66 FX2N-32DP-IF USER'S MANUAL(PROFIBUS- DP Interface Unit)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_64_65_66.pdf
67 FX2N-422-BD USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_67.pdf
68 FX2N-485-BD USER'S GUIDE
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_68.pdf
69 FX2N-4AD USER'S GUIDE(4CH INPUT-ANALOG SPECIAL FUNCTION BLOCK
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_69.pdf
70 FX2N-4AD-PT USER'S GUIDE(4CH PLATINUM TEMPERATURE SENSORS)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_70.pdf
71 FX2N-4AD-TC USER'S GUIDE(4CH THERMOCOUPLE SENSORS)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_71.pdf
72 FX2N-4DA USER'S GUIDE(4CH OUTPUT-ANALOG SPECIAL FUNCTION BLOC
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_72.pdf
73 FX2N-64DNET
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_73.pdf
74 FX2N-8AD
75 FX2N-8AD USER'S GUIDE(8CH INPUT-ANALOG SPECIAL FUNCTION BLOCK
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_74_75.pdf
76 FX2NC HARDWARE MANUAL
77 FX2NC(-D,UL) SERIES HARDWARE MANUAL
78 FX2NC(DSS,DS) SERIES HARDWARE MANUAL
79 FX2NC-DS User's Guide
80 FX2NC-DUL User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_76_80.pdf
81 FX2N-GM Connection Sheet
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_81.pdf
82 FX2N-GM Hardware and Programming Manual
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_82.pdf
83 FX-485PC-IF HARDWARE MANUAL(RS-485 Interface Unit)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_83.pdf
84 FX-485PC-IF USER'S MANUAL(RS-485 Interface Unit)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_84.pdf
85 FXFX0N-485ADP User's Guide
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_85.pdf
86 Positioning Control
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_86.pdf
87 PROGRAMMING MANUAL (FX0,FX0S,FX0N,FX,FX2C,FX2N,FX2NC)
http://www.5130cn.com/luntan/ziliao/Fx_plc/fx_plc_87.pdf
88 PROGRAMMING MANUAL II (FX1S,FX1N,FX2N,FX2NC)
89 SC09接线图
http://www.5130cn.com/luntan/ziliao/Fx_plc/sc09.bmp
  • 下载积分:+2(shalinplc) 鼓励一下!
  • 下载积分:+4(jake2008y) 热心助人!
    zyfzxh
    精华主题: 12 篇
    发帖数量: 6113 个
    工控威望: 7523 点
    下载积分: 110393 分
    在线时间: 4867(小时)
    查看zyfzxh的 主题 / 回贴
    1楼  发表于: 2008-09-03 16:41
    樓主都重新檢查一下吧!不能下載!
    jake2008y
    精华主题: 3 篇
    发帖数量: 1266 个
    工控威望: 3174 点
    下载积分: 7881 分
    在线时间: 258(小时)
    查看jake2008y的 主题 / 回贴
    2楼  发表于: 2008-09-04 08:20
    是有些个确实无法下载。楼主再看看。
    [ 此帖被jake2008y在2008-09-04 08:36重新编辑 ]
    jake2008y
    精华主题: 3 篇
    发帖数量: 1266 个
    工控威望: 3174 点
    下载积分: 7881 分
    在线时间: 258(小时)
    3楼  发表于: 2008-09-04 08:27
    先顶一下,资料是好的,只是英文版多数人看起来很费力,楼主有中文有吗?
    jake2008y
    精华主题: 3 篇
    发帖数量: 1266 个
    工控威望: 3174 点
    下载积分: 7881 分
    在线时间: 258(小时)
    4楼  发表于: 2008-09-04 08:47
    有些下载不了,大家可以直接进入楼主提供的下面地址去下载
    http://www.5130cn.com/30ziliao_fx_plc.htm
    [ 此帖被jake2008y在2008-09-04 17:18重新编辑 ]
    she012916
    5楼  发表于: 2008-09-04 13:49
    我再找些中文的资料,无法下载可能是由于时间长给删了。
    she012916
    6楼  发表于: 2008-09-04 14:05
    我在网上差了,没中文的,下载不了是由于论坛上的源地址被删了吧。不好意思啊!!大家将就着看吧,顺便学学读英文资料的能力。不过多数人说看资料一般看英文原版的,我也在第一次做东西是慢慢学着看的。
    glpptym
    发帖数量: 1721 个
    工控威望: 3229 点
    下载积分: 202482 分
    在线时间: 719(小时)
    查看glpptym的 主题 / 回贴
    7楼  发表于: 2008-10-23 09:33
    看一看。
    shalinplc
    查看shalinplc的 主题 / 回贴
    8楼  发表于: 2008-10-24 18:50
    支持共享,谢谢
    glpptym
    发帖数量: 1721 个
    工控威望: 3229 点
    下载积分: 202482 分
    在线时间: 719(小时)
    查看glpptym的 主题 / 回贴
    9楼  发表于: 2008-10-25 09:35
    继续支持好资料。
    glpptym
    发帖数量: 1721 个
    工控威望: 3229 点
    下载积分: 202482 分
    在线时间: 719(小时)
    查看glpptym的 主题 / 回贴
    10楼  发表于: 2008-10-26 19:46
    好资料,继续顶!
    huangjiahong
    天才也是百分九十九的血汗加百分一的灵感
    发帖数量: 850 个
    工控威望: 523 点
    下载积分: 3758 分
    在线时间: 317(小时)
    查看huangjiahong的 主题 / 回贴
    11楼  发表于: 2008-10-27 08:29
    先顶一下
    有你的帮助!我的学识更进步
