dosgao
苏州必盛科技有限公司罗克韦尔AB,西门子以及其他系统设计,集
发帖数量: 98 个
工控威望: 1071 点
下载积分: 1660 分
在线时间: 114(小时)
查看dosgao的 主题 / 回贴
楼主  发表于: 2025-10-07 13:32
System features
Logix Designer application version v38.00 has these new and enhanced features.
New features
Support for ControlLogix 5590 controllers
This version of the Logix Designer application supports ControlLogix 5590 controllers. By default, ControlLogix 5590 controllers operate as Safety controllers. You can also configure them as Standard, Process, and Process Safety controllers.
Synchronize EPLAN projects with Logix Designer projects
Use the new Synchronize dialog to compare EPLAN AML project files with a project in the Logix Designer application. Use the Synchronize dialog to add project components to the open project or to the EPLAN AML project to keep them in synch. Synchronizing projects:
Saves repetitive editing--make updates in one project and synchronize them in others.
Minimizes human error when working across multiple systems.
Helps keep your device data consistent and up-to-date across your software tools. The Synchronize feature also expands the number of supported devices.
See the Logix Designer online help for more information:
https://www.rockwellautomation.com/en-us/docs/studio-5000-logix-designer/38-00/contents-ditamap/studio-5000-logix- designer/import-and-export/data-exchange.html
Generate Safety Signatures in Run mode
In this version of the Logix Designer application, you can generate a Safety Signature for ControlLogix 5590 and 5590XT, GuardLogix 5580, and Compact GuardLogix 5380 controllers when they are in Program and Remote Run modes.
https://www.rockwellautomation.com/en-us/docs/studio-5000-logix-designer/38-00/contents-ditamap/studio-5000-logix- designer/controller-properties/editing-controller-properties/controller-properties-dialog-box---safety-tab/controller-properties- dialog-box---safety-tab-sett.html
Front-port crossloading redundancy on ControlLogix 5590 controllers
This version of the Logix Designer application adds front-port crossloading on a ControlLogix 5590 controller in a redundant project to improve the scan performance of tasks. When you enable front-port crossload, the controller blocks traffic on the front Ethernet ports and they cannot be used for browsing to other devices or links.
Enhanced features
New Timer_T data type
This version of the Logix Designer application includes the TIMER_T data type. The TIMER_T data type:
Further integrates the DateTime feature into the Logix Designer instruction set. You can set the Timer operand as TIMER or TIMER_T in the Timer On Delay (TON), Timer Off Delay (TOF), and Retentive Timer On (RTO) instructions. The TIMER_T data type has Accumulated (ACC) and Preset (PRE) members whose data type is TIME.
Clarifies elapsed time by displaying values in units of time: days (d), hours (h), minutes (m), seconds (s), milliseconds (ms), and microseconds (us). You no longer need to derive ACC or PRE values from a DINT that represents milliseconds.
FGEN instruction supported in safety applications
In this version of the Logix Designer application, you can use the Function Generator (FGEN) instruction in safety applications.
Corrected Anomalies in This Release
苏州必盛科技有限公司
rslogix
发帖数量: 24 个
工控威望: 115 点
下载积分: 699 分
在线时间: 254(小时)
查看rslogix的 主题 / 回贴
1楼  发表于: 2025-10-07 14:51
这个方便的话也给我一份325146707@.com.谢谢
weikvp
weɪk ʌp
发帖数量: 1021 个
工控威望: 2538 点
下载积分: 256 分
在线时间: 395(小时)
查看weikvp的 主题 / 回贴
2楼  发表于: 2025-10-07 15:39
感谢分享
welcome:4057363
zjsckan
zjkaikai;QQ:598798210
发帖数量: 482 个
工控威望: 7447 点
下载积分: 20251 分
在线时间: 9712(小时)
查看zjsckan的 主题 / 回贴
3楼  发表于: 2025-10-08 20:03
还没见到网盘资源,期待中
威伦禁止反编译(恢复宏指令);WINCC画面密码;海泰克重建应用密码;组态王工程密码;Studio5000源密码保护等。微信:hkcs-001,QQ:598798210
东晟智能2026
发帖数量: 285 个
工控威望: 381 点
下载积分: 912 分
在线时间: 21(小时)
查看东晟智能2026的 主题 / 回贴
4楼  发表于: 13天前
感谢分享
