hgz284631157
工控小君
发帖数量: 564 个
工控威望: 669 点
下载积分: 2318 分
在线时间: 231(小时)
查看hgz284631157的 主题 / 回贴
楼主  发表于: 2025-12-17 09:15
EPLAN Electric P8 2.9 SP1 (x64)
安装完成激活后可以打开软件,重启电脑就出现 选择许可 窗口,确定按钮灰色的重新再次激活也是这样。
卸载重新安装软件,又只能打开一次不能重启电脑。
系统WIN10 X64专业版
如何破局求高手指教 感谢!
520arrow
发帖数量: 240 个
工控威望: 342 点
下载积分: 1516 分
在线时间: 170(小时)
查看520arrow的 主题 / 回贴
1楼  发表于: 2025-12-17 11:21
For ePlan versions 2.6-2.9
Windows (7-10-11) x64 prof... (or enterprise) and not lower.
Windows 7 requires NET Framework 4.7.2
Microsoft Visual C++ Redistributable 2019
For ePlan versions 2022 and above, only Windows (10-11) x64 prof... (or enterprise) and above.
https://www.eplan.help/en-us/Infoportal ... rovals.htm
1. Install the program
2. Open C:\Windows\System32\drivers\etc\hosts
Insert the following lines:
0.0.0.0 eplan.prod.sentinelcloud.com
0.0.0.0 licensingservice.epulse.cloud
0.0.0.0 licensingservice.eplan.com
127.0.0.1 eplan.prod.sentinelcloud.com
127.0.0.1 licensingservice.epulse.cloud
127.0.0.1 licensingservice.eplan.com
/or copy the finished one from the Crack folder/
3. Generate a license using Keygen\EPlanKeygen.exe:
Run EPlanKeygen.exe
Download TPL: select file - EPLAN_Electric_P8_Professional, or another, in the same folder as Keygen,
In the serial field, enter: WUP0UXXXXX (X is any combination of numbers), click Create.
EPlanKeygen CAM will generate and save the lservrc file in C:\Users\Public\EPLAN\Common
4. Open the generated lservrc, add 2 lines at the very beginning of the file:
"No Identity Check"
"Skip Identity Check"
(as it is). Save.
The item can be omitted if the following modules are installed in the Keygen configuration (see TPL):
Module_1450=Skip Identity Check
Module_30108=No Identity Check
5. Run EPlanPatcher, set all checkboxes
All necessary Dll-ki will be generated there - where it is necessary!
6. Everything..! Launch EPlan
p.s. run all programs as administrator
Tested on v2.6 (specially installed due to PPE), 2.9 and 2022 (2023 with a known issue).
All work "in parallel", i.e. simultaneously!
The function of copying between versions via the shared clipboard /Ctrl/+C, /Ctrl/+V also works.
https://disk.yandex.ru/i/Y0dNNvwfKZZwoQ
hqokabc
发帖数量: 259 个
工控威望: 278 点
下载积分: 1020 分
在线时间: 18(小时)
查看hqokabc的 主题 / 回贴
2楼  发表于: 2025-12-18 19:29
把安装目录列入防毒排除项
zzk139
发帖数量: 51 个
工控威望: 198 点
下载积分: 675 分
在线时间: 72(小时)
查看zzk139的 主题 / 回贴
3楼  发表于: 2025-12-18 22:17
不要勾选全部显示就可以
zhengtiguo
上善若水
发帖数量: 609 个
工控威望: 667 点
下载积分: 5794 分
在线时间: 147(小时)
查看zhengtiguo的 主题 / 回贴
4楼  发表于: 2025-12-19 09:03
学习学习
深耕技术
li19930121
发帖数量: 1018 个
工控威望: 2581 点
下载积分: 4132 分
在线时间: 452(小时)
查看li19930121的 主题 / 回贴
5楼  发表于: 2025-12-19 11:43
https://blog.csdn.net/Qinmingyue13/article/details/153474227  照着做就行,
激活过以后,过一段时间打开提示没有license,一般就是没有找到激活的tpl文件,只需要重新激活,不需要卸载重装更不需要重转系统
hgz284631157
工控小君
发帖数量: 564 个
工控威望: 669 点
下载积分: 2318 分
在线时间: 231(小时)
6楼  发表于: 2025-12-22 16:07
2楼正解,感谢!
ytlytl
发帖数量: 166 个
工控威望: 678 点
下载积分: 4523 分
在线时间: 170(小时)
查看ytlytl的 主题 / 回贴
7楼  发表于: 2025-12-22 17:05
学习学习
